This command is used to set the number of retries the switch will attempt. This value may be global or on a per server basis.
| mgmt-access | RADIUS authentication for management access |
| netlogin | RADIUS authentication for netlogin access. |
| primary | Primary server. |
| secondary | Secondary server. |
| index | RADIUS server index. |
| retries | RADIUS server retries. |
| retries | RADIUS sever retries. Range 1-20. |
The default value is 3, with a range of 0-10.
None.
This command was first available in ExtremeXOS 16.1.
